From the Bitcraze exmaple. I am able to write the loco anchor points via the python script.
I was wondering which func should i sue to read the loco anchor points via python script?
Reading LPS Anchor Points
Re: Reading LPS Anchor Points
Hi and sorry for the delay due to the easter holiday!
Which example are you referring to? Could you post an URL of that here?
I am using the "lopo.setposition(x,y,z)" functions from lpslib.lopoanchor
You should use the LocoMemory2 class in the python lib to read anchor data from the Crazyflie.
There is a (slightly messy) example in the client https://github.com/bitcraze/crazyflie-c ... ab.py#L272
