Controlling Crazyflie with LPS
youngbin1130
Post by youngbin1130 » Mon Mar 02, 2020 9:23 am
I was looking through the Python library for Crazyflie but I'm confused about where I should start for my project because, from what I understand, there are alot of similar functions.
I would just like to see where the following functions are:
1. The turning velocity
2. Moving from Point A to Point B (In world space)
3. Moving along the relative X, Y, Z
I would also like to ask if I start off with a single Crazyflie, whether the functions can be accommodated for a Swarm in the future.
Cheers,
Youngbin
Re: Controlling Crazyflie with LPS
Post by kimberly » Mon Mar 02, 2020 3:42 pm
Hi.
So the examples/position_commander_demo.py in that same repo is already doing number 2 and 3 of your request. Motion_commander_demo.py does 1 and 3 but do be carefule of mixing the types of 'commanders' (see this issue).
You can look in the examples/swarm/ folder for some examples for flying multiple Crazyflies at the same time.
youngbin1130
Post by youngbin1130 » Fri Mar 06, 2020 5:57 am
Thanks for your reply!
I had forgotten to mention that if all my questions take into account the boundary set by the LPS nodes.
Also, I think you had forgotten to link the issue which you wanted to mention when mixing two kinds of commanders.
Post by kristoffer » Fri Mar 06, 2020 9:28 am
I'm not sure what you mean, could you please explain a bit further?
The issue Kimberly referred to was https://github.com/bitcraze/crazyflie-f ... issues/536
youngbin1130
Post by youngbin1130 » Thu Mar 12, 2020 3:09 am
Basically, I would like to control the Crazyflie to move from (x,y,z) to (x1,y1,z1) within inside the LPS "box" while being able to access low level commands.
I have taken a look at the examples/position_commander_demo.py and tested it on my Crazyflie. It seems to behave a little strangely on my Crazyflie. When running the first "pc.forward(1.0)", I've noticed that the Crazyflie flies backwards diagonally and I'm not sure what the expected behaviour is. Here is the link to the video: https://youtu.be/7WKfWd7pX-s
Also after further research, I've noticed that examples/autonomousSequence.py has a similar function (moving from Point x,y,z to x1,y1,z1) using the set_position setpoint. How is this different with the position_commander_demo.py or is there any difference at all?
Post by kristoffer » Mon Mar 16, 2020 12:59 pm
That looks a bit weird. your system set up looks pretty good, I guess you have double checked that the anchors positions are correct?
Just to make sure, the Crazyflie must be oriented facing the positive X direction when taking off.
pc.forward(1.0) should move one meter in the forward direction.
Maybe you should start by taking off and landing. The easiest way should be to replace the motion commands with a time.sleep(5)
There are many ways to do it :-)
In the autonomousSequence.py script we continuously send setpoints to the Crazyflie. In position_commander_demo.py the high level commander handles that on board the Crazyflie instead.
youngbin1130
Post by youngbin1130 » Tue Mar 31, 2020 8:33 am
I've check and confirmed that my Crazyflie is facing the correct direction. I will start by taking off and landing, as per your suggestion.
Also, I would like to ask regarding the Github which you and Kimberly linked met to. If I'm understanding this correctly, if I set lower-level commands and run high level commands afterwards, the lower level commands doesn't override the higher level commands? So does this mean that I am unable to combine the linear/angular velocity variable with the go_to functions in worldspace?
Finally, I would also like to ask if it is possible for the example/autonomousSequence.py to work within a swarm environment? For my project, I would like to use the variable "YAW" within the sequence of autonomousSequence.py but, so far, I've only manage to make the swarm system work in only the example/SwarmSequence.py.
My team is currently trying to use a machine learning model and bringing those accumulated data from a simulated environment so being able to use the three variables I mentioned at the beginning of this post would be really great.
Thanks for all the help! Hope you stay well and healthy during this time period. Cheer!
Post by kimberly » Tue Mar 31, 2020 1:29 pm
Hmm yes good question. It is fine as long as you are not changing the commander type I believe. If you just use the regular commander: https://github.com/bitcraze/crazyflie-l ... mmander.py, it has both functionalities for sending angle setpoints and position velocity setpoints. That might be able to work as well. I might work on this myself since I'm working on tuning scripts for the PID attitude controller
So in the swarm example you mentioned, you can change yaw if you want: https://github.com/bitcraze/crazyflie-l ... ce.py#L268. The last value in this send function is in fact yaw and just zero for now. If you add the wanted yaw value in the sequence structure ( on top of the script, where for now there is just x,y,z and time), your able to input yaw there as well.
You stay healthy as well!
youngbin1130
Post by youngbin1130 » Tue Apr 07, 2020 7:13 am
Thanks for the reply Kimberly!
I'll look into the commander.py!
Just another quick question. I was trying to run exmaple/Motion_Commander_demo.py using the my Crazyflie and the LPS nodes but it would either not take off take off the floor or touch the floor during the sequence. I've checked my propellers and they are in the correct orientation. I've attached a video my Crazyflie running this. I'm pretty sure this isn't the intended behavior.
https://youtu.be/thxPbXRfI7g
Cheers.
Post by kimberly » Tue Apr 07, 2020 7:57 am
Thanks for sharing the video.
Actually, the flight looks pretty good but it's flying a bit low. I think that the state estimation is a bit off. If you place your crazyflie on the floor and look at state.Z log in the plotter of the cfclient, what does it say?
By the way, it looks like you have setup your lab now at your place? Can you let us know more or can we share this with the rest of the community? We are currently trying to help out and inspire users to continue their work at home in this current situation.
