LPS Anchor working problem.
juju
Post by juju » Thu Jan 16, 2020 5:06 am
Hi guys, I found some problems.
There is no problem with the Anchors I bought a year ago. But Recently purchased products have a problem.
If i connect the new Anchor to the CF2, Attitude(Roll,Pitch,Yaw) does not work on the program.The same goes for position Data.
we've got lps-node-firmware-2019.09 (1).dfu firmware.
I'd appreciate it if you could tell me what the problem is.
Re: LPS Anchor working problem.
Post by kimberly » Thu Jan 23, 2020 10:34 am
We need to get a bit more information about your problem.
So to understand correctly, the new LPS nodes have the latest firmware, but you are not getting position data?
Can you see if the crazyflie is set on the same ranging mode as the LPS nodes are configured too ? Can you see them in the cfclient at all?
