EKF variance and CMSIS nan values
Guglie
Post by Guglie »
Hi, I've noticed that sometimes the EKF reaches high variance in
stateEstimatorScalarUpdate()
and that leads to a filter reset.
This is due to
mat_mult()
(from CMSIS-DSP library) returning inf or nan values sometimes.
Have you experienced the same thing? How can I reduce this to achieve better positioning?
Re: EKF variance and CMSIS nan values
With what firmware version have you observed this?
We have seen some occurence of the EKF diverging mostly when starting the Crazyflie well outside the TDOA system. We have tried to isolate the points where a NaN could appear and solve it over time but maybe there is still some left.
Can you see a pattern of for when this kind of problem happen?
Guglie
Post by Guglie »
Hi arnaud, thanks for your reply,
So the matrix multiplication from CMSIS library is known to have some specific values that do not work?
I'm using a custom firmware to understand and maybe test sightly changes of the TDoA2 localization algorithm, can you explain (or point me where to look at) how you isolated the points and solve it?
