ESP8266 implementation with LPS node
Killitz
Post by Killitz »
Hi
I notice the Exp connector for ESP8266 on the LPS node, but i can't find any implementation on the software...can someone help me?
Re: ESP8266 implementation with LPS node
Yes, the connector is for a ESP8266 01 module. I put it in on an early prototype and then we decided to keep it. Unfortunately I've never had the time to implement any software for it. It's connected to one of the serial ports on the STM so it should be possible to talk to the module though it.
Killitz
Post by Killitz »
Thanks for the fast reply, I will try to do something... do you have any suggestion on where I can find libraries?
Best regards
Luca
Libraries for using the UART on the STM32 are in the library from ST. You can find the API for the UART here. Initially we used an FTDI cable before the USB was implemented and this code is still in, but removed at compile time with the macro USE_FTDI_UART. Search for that in the code and you'll get an idea of how to use the UART.
