test loco position but cfclient no any response
justinleeyang
Post by justinleeyang » Sun May 27, 2018 4:33 pm
hi,
we try to update the loco anchor and cf2 to newest code, but find cfclient don't any respone,
we have alreadly force the range mode with twr, console info as following:
DECK_DRIVERS: Found 14 drivers
DECK_INFO: Found 0 deck memory.
DECK_INFO: compile-time forced driver bcDWM1000 added
DECK_CORE: 1 deck enumerated
MPU9250 I2C connection [OK].
AK8963 I2C connection [OK].SYS: -------------------------CFGBLK: v1, verification [OK]
LPS25H I2C connection [OK].
ESTIMATOR: Using estimator 2
PLATFORM: Low interference mode. NRF51 TX power reduced by -12db.
EEPROM: I2C connection [OK].
AK8963: Self test [OK].
DECK_CORE: Deck 0 test [OK].
DWM: Switching mode to TWR
SYS: Free heap: 15520 bytes
we see the dwm100deck led toggle ok, 6 anchors led toggle also ok, but the cfclient still gray,
justinleeyang
Re: test loco position but cfclient no any response
Post by justinleeyang » Mon May 28, 2018 7:19 am
hi,
lps-node-firmware, the uwbConfig->positionEnabled must enable ?
Post by arnaud » Mon May 28, 2018 1:57 pm
What is the state of your system? what firmware verison are you using in lps node and Crazyflie and what hardware are you using (stock or self-made?). What client version are you using?
One possibility is that the tab is checking the LPS deck one wire memory VID/PID in order to enable itself, you can easily find the code for it in the lps tab. If you do not have a programmed one wire memory, the tab will not be enabled. Ideally we should use the parameter that indicates that the LPS deck driver is started instead (pull request is welcome :-).
justinleeyang
Post by justinleeyang » Mon May 28, 2018 3:20 pm
hi, arnaud:
config.mk add the code:
CFLAGS += -DDECK_FORCE=bcDWM1000
crazyflie with dwm1000deck force to support dwm1000 with twr mode, according to the dwm1000deck led toggle, range successfully with anchor 0~5.
we use the VM201801 version firmware. crazyflie stock, dwm1000deck self-made.
201801 release version.
lps deck is dwm1000deck? must add one wire memory? we design the dwm1000board, but remove the one memory.
Post by arnaud » Mon May 28, 2018 4:04 pm
If you do not want to mount and program a OW memory you can hardcode this variable to 'True' in the client: https://github.com/bitcraze/crazyflie-c ... #L662-L663. As I said, in the future it might be better to test the parameters if the LPS has been started instead of testing the memory.
justinleeyang
Post by justinleeyang » Mon May 28, 2018 4:27 pm
you are right, thanks!
justinleeyang
Post by justinleeyang » Sun Jun 03, 2018 7:10 am
according to :
another issue, open Tab Filght Control and Console, cfclient run ok, but when open the tab Loco Positioning, the cfclient run very slowly. the console report infomation:
Post by arnaud » Mon Jun 04, 2018 10:42 am
What version of the VM are you using? It seems to be a problem with pyqtgraph. You could try to re-install it from pip with a series of command like:
sudo apt-get remove python3-pyqtgraph
pip3 uninstall pyqtgraph
pip3 install pyqtgraph
justinleeyang
Post by justinleeyang » Mon Jun 04, 2018 11:19 am
VM2018.1.03
Post by arnaud » Mon Jun 04, 2018 11:40 am
Have you tried to remove and re-install pyqtgraph?
