tdoa distance diff error
justinleeyang
Post by justinleeyang » Sat Mar 24, 2018 10:41 am
hi,
tdoa anchor mode:
#define NSLOTS 8
#define TDMA_SLOT_BITS 26 // 26: 2ms timeslot
#define TDMA_NSLOT_BITS 3
about the distance difference between anchors, the right value should be ~0.3m, get many wrong value as follow:
314852.0000
314756.0000
358941.0000
then adjust the TDMA_SLOT_BITS to 27, the wrong value reduce, but occurs once Occasionally.
why?
Re: tdoa distance diff error
Post by arnaud » Mon Mar 26, 2018 9:56 am
Do you get spikes, intermittent bad values, or is it consistently wrong?
Guglie
Post by Guglie » Mon Mar 26, 2018 5:29 pm
Very interesting, I'm also trying to get better results from TDOA, what are the TDMA_SLOT_BITS?
justinleeyang
Post by justinleeyang » Tue Mar 27, 2018 2:45 am
hi, arnaud:
when TDMA_SLOT_BITS set as 26, consistently wrong;
then set as 27, intermittent bad values.
Post by arnaud » Wed Mar 28, 2018 7:45 am
Hum, this looks like packet collision. Are you using un-modified firmware or have you changed anything. I am thinking about radio settings that could change the packet timing.
justinleeyang
Post by justinleeyang » Wed Apr 04, 2018 12:08 pm
yes, I open other tag or anchor, they send ~30 packets per second, so affect my tdoa anchors and tag receive result in distance diff error.
Post by arnaud » Fri Apr 06, 2018 6:08 am
What version of the node firmware are you using (what git commit)?
