I don't understand the main function of the following code:
// Change and init algorithm uppon request
// The first time this loop enters, currentRangingMode is set to auto which forces
// the initialization of the set algorithm
if (algoOptions.rangingMode == lpsMode_auto) { // Auto switch
if (algoOptions.rangingModeDetected == false) {
if (algoOptions.currentRangingMode == lpsMode_auto) {
// Initialize the algorithm, set time for next switch
algoOptions.nextSwitchTick = xTaskGetTickCount() + LPS_AUTO_MODE_SWITCH_PERIOD;
// Defaults to TDoA algorithm
algoOptions.currentRangingMode = lpsMode_TDoA;
algorithm = algorithmsList[algoOptions.currentRangingMode].algorithm;
algorithm->init(dwm, &algoOptions);
timeout = algorithm->onEvent(dwm, eventTimeout);
} else if (xTaskGetTickCount() > algoOptions.nextSwitchTick) {
// Test if we have detected anchors
if (algoOptions.autoStarted && algorithm->isRangingOk()) {
algoOptions.rangingModeDetected = true;
DEBUG_PRINT("Automatic mode: detected %s\n", algorithmsList[algoOptions.currentRangingMode].name);
} else {
// We have started the auto mode by initializing the next modes
algoOptions.autoStarted = true;
// Setting up next switching time
// Switch to next algorithm!
if ((algoOptions.currentRangingMode+1) > LPS_NUMBER_OF_ALGORITHM) {
algoOptions.currentRangingMode = 1;
} else {
algoOptions.currentRangingMode++;
} else if (algoOptions.currentRangingMode != algoOptions.rangingMode) { // Set modes
// Reset auto mode
algoOptions.rangingModeDetected = false;
algoOptions.autoStarted = false;
if (algoOptions.rangingMode < 1 || algoOptions.rangingMode > LPS_NUMBER_OF_ALGORITHM) {
DEBUG_PRINT("Trying to select wrong LPS algorithm, defaulting to TDoA!\n");
algoOptions.currentRangingMode = algoOptions.rangingMode;
algorithm = algorithmsList[lpsMode_TDoA].algorithm;
} else {
DEBUG_PRINT("Switching mode to %s\n", algorithmsList[algoOptions.currentRangingMode].name);
