Unable to Open LPS Configuration toolbox
rajavardhanr6
Post by rajavardhanr6 » Tue Dec 12, 2017 11:44 am
I’m trying to update the node using LPS Configuration tool, but I’m not able to open it. I followed the instruction given in tutorial and also I’m using proper USB Cable.Unable to figure out what the mistake I’m making.
Do I need to open LPS configuration tool separately or it will open automatically when i connect the node using USB?
https://www.bitcraze.io/getting-started ... ng-system/
Any suggestions or help welcome
Re: Unable to Open LPS Configuration toolbox
Post by arnaud » Thu Dec 14, 2017 9:05 am
The LPS configuration tool is a software that you need to install and run on your computer. If you are on windows there is an installer, if you are on other system you can run it quite easily from source https://github.com/bitcraze/lps-tools#r ... nstruction
