I am new in using both the crazyflie loco positionning system and Ubuntu.
after configuring the crazyflie, I tried to implement the loco positionning system, and hence update the 6 nodes before configuring them into anchor.
Nevertheless, the "update" button is not cliquable, even after having browse the lps-node-firmware/bin/lps-node-firmware.dfu file, event in DFU mode.
Do you know the requirements to make the DFU mode of the node accesible ?
Update the node - mode DFU
Re: Update the node - mode DFU
It might be an access right problem, can you try to run the lps-tools with sudo?
