I'm trying to test two node distance sensing. I set one node to a tag and the other to anchor through the terminal. I see that the tag is now searching for anchors but I don't see distance measurements. How would I go about getting those readings?
Dave
Two node distance
Re: Two node distance
The node in tag mode will scan 6 anchors by default (currently you have to modify the source code to change that). If your anchor is set to an ID that is scanned by the tag, the distance to the anchor will be shown. What ID did you set in the anchor?
