Failed to set anchor number on LPS with picocom
smarka
Post by smarka »
Following the instructions in the video <https://www.bitcraze.io/loco-pos-system/> I attempted to set the number for the anchor and it seems that the anchor set it for a very short time then it reset it back to zero immediately... (I did fail with flashing the node for the latest firmware I purchased the loco kit in Feb.)
bitcraze@bitcraze-vm:~/projects/lps-node-firmware$ sudo picocom /dev/ttyACM0
picocom v1.7
port is : /dev/ttyACM0
flowcontrol : none
baudrate is : 9600
parity is : none
databits are : 8
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
nolock is : no
send_cmd is : sz -vv
receive_cmd is : rz -vv
imap is :
omap is :
emap is : crcrlf,delbs,
Terminal ready
85732303920
TEST : Initializing pressure sensor ... [OK]
TEST : Pressure sensor self-test ... [OK]
TEST : EEPROM self-test ... [OK]
CONFIG : EEPROM configuration read and verified
TEST : Initialize UWB ... [OK]
CONFIG : Address is 0x0
CONFIG : Mode is TWR Anchor
CONFIG : Tag mode anchor list (6): 0x01 0x02 0x03 0x04 0x05 0x06
CONFIG : Anchor position enabled: false
SYSTEM : Node started ...
SYSTEM : Press 'h' for help.
Previous device mode: TWR Anchor
New device mode: TWR Anchor
EEPROM configuration changed, restart for it to take effect!
Updating address to 0x01
Device address: 0x1
FATAL: term closed
term_exitfunc: reset failed for dev UNKNOWN: Input/output error
picocom v1.7
flowcontrol : none
baudrate is : 9600
parity is : none
databits are : 8
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
nolock is : no
imap is :
omap is :
FATAL: cannot open /dev/ttyACM0: No such file or directory
picocom v1.7
flowcontrol : none
baudrate is : 9600
parity is : none
databits are : 8
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
nolock is : no
imap is :
omap is :
Terminal ready
Updating address to 0x00
Device address: 0x0
Device address: 0x1
Device address: 0x0
FATAL: term closed
picocom v1.7
flowcontrol : none
baudrate is : 9600
parity is : none
databits are : 8
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
nolock is : no
imap is :
omap is :
Terminal ready
Device address: 0x1
Device address: 0x0
Device address: 0x1
Device address: 0x0
FATAL: term closed
Re: Failed to set anchor number on LPS with picocom
Since the dfu flashing should have been solved in another thread, is the problem still present if you are running with the latest firmware?
