110Kbps don't work
justinleeyang
110Kbps don't work
Post by justinleeyang » Mon Feb 27, 2017 4:05 pm
Hi, All:
I want to try the 110Kbps, but range don't work, anchor only receive the data, but don't return data to tag.
justinleeyang
Re: 110Kbps don't work
Post by justinleeyang » Tue Feb 28, 2017 5:12 am
Hi, all:
I find the config as following:
void dwSetDataRate(dwDevice_t* dev, uint8_t rate) {
	rate &= 0x03;
	dev->txfctrl[1] &= 0x83;
	dev->txfctrl[1] |= (uint8_t)((rate << 5) & 0xFF);
	// special 110kbps flag
	if(rate == TRX_RATE_110KBPS) {
		setBit(dev->syscfg, LEN_SYS_CFG, RXM110K_BIT, true);
	} else {
		setBit(dev->syscfg, LEN_SYS_CFG, RXM110K_BIT, false);
	// SFD mode and type (non-configurable, as in Table )
	if(rate == TRX_RATE_6800KBPS) {
		setBit(dev->chanctrl, LEN_CHAN_CTRL, DWSFD_BIT, false);
		setBit(dev->chanctrl, LEN_CHAN_CTRL, TNSSFD_BIT, false);
		setBit(dev->chanctrl, LEN_CHAN_CTRL, RNSSFD_BIT, false);
	} else {
		setBit(dev->chanctrl, LEN_CHAN_CTRL, DWSFD_BIT, true);
		setBit(dev->chanctrl, LEN_CHAN_CTRL, TNSSFD_BIT, true);
		setBit(dev->chanctrl, LEN_CHAN_CTRL, RNSSFD_BIT, true);
	uint8_t sfdLength;
		sfdLength = 0x08;
	} else if(rate == TRX_RATE_850KBPS) {
		sfdLength = 0x10;
	} else {
		sfdLength = 0x40;
	dwSpiWrite(dev, USR_SFD, SFD_LENGTH_SUB, &sfdLength, LEN_SFD_LENGTH);
	dev->dataRate = rate;
and I also check the dw1000 user manaul,
so I think that when data rate 110kbps:
} else {
Post by arnaud » Wed Mar 01, 2017 9:50 am
I have never tried to run the radios in 110K mode. Is it working with your modifications?
justinleeyang
Post by justinleeyang » Fri Mar 03, 2017 11:48 pm
hi, arnaud:
sorry, the later reply.
I don't change the two line code, my rxtimeout time too short result in communication fail, add the timeout to ~20ms, pass.
Post by arnaud » Mon Mar 06, 2017 12:20 pm
Ok, so the current code works for 110kbps, good to know. Thanks.
