Hi there,
I'm currently working on setting up a lab for my thesis. While not having much experience with this kind of stuff, the topic is just fascinating.
I have set up all 6 nodes and can can see them in rviz, yet the displayed location of the drone is just utterly wrong.
What steps can I take to debug the problem?
Regards,
Simon
Unable to locate Crazyflie properly with LPS
Re: Unable to locate Crazyflie properly with LPS
I'm having the same problem as well
First I would look at the ranges from the Crazyflie to the anchor. You can do that using rqtplot: Start the hover launchfile, launch rqt_plot, display /crazyflie/ranging/ranges[0] to [5]. This will show you the distance measurement to all the anchor and will allow you to verify that the ranges are correct and the anchor mapping is right: getting closer to anchor address 1 should make /crazyflie/ranging/ranges[0] smaller.
/Arnaud
/Arnaud
Running rqt_plot returns the following messages in the terminal:
TopicCompleter.update_topics(): could not get message class for topic type "crazyflie_driver/GenericLogData" on topic "/crazyflie/log_ranges"
TopicCompleter.update_topics(): could not get message class for topic type "bitcraze_lps_estimator/RangeArray" on topic "/crazyflie/ranging"
TopicCompleter.update_topics(): could not get message class for topic type "crazyflie_driver/GenericLogData" on topic "/crazyflie/log_kfpos"
TopicCompleter.update_topics(): could not get message class for topic type "crazyflie_driver/GenericLogData" on topic "/crazyflie/log_kfqt"
How do I see the ranges in the window that opens?
Simon
Simon
This looks like you did not source the "devel/setup.bash" workspace file in the console you are launching rqt_plot (https://wiki.bitcraze.io/doc:lps:index#ros)
That did the trick!
Turns out only 2 of the anchors were actually returning non-zero values. Reflashing the firmware and reconfiguring the nodes solved that and I can now properly locate my crazyflie. Thank you!
Glad that it helped! Have fun with autonomous flying .
