connect client on vm
Client is inoperable after running Update all project on the vm. I think there was a damage during the file modification process. Can you check the file on the git-hub?
Re: connect client on vm
There has been some recent updates that added a new dependency, maybe this is the problem? Please see viewtopic.php?f=5&t=4483
You can read more about this in client issue https://github.com/bitcraze/crazyflie-c ... issues/451
I also created an issue for the VM for a more longterm solution https://github.com/bitcraze/bitcraze-vm/issues/48
