i'm building a similar quadcopter but using a PIC32 and i want to use the same motor and motor mount of the crazyflie and i would like to know what is the thickness of the pcb so the motor mounts will fit. I didn't find this info on the wiki page.
PCB thickness
Re: PCB thickness
It is a standard 1.6mm thick PCB.
Re: PCB thickness
Can you tell me what is the scale (dimensions) of your quadcopter? I am also want to build similar quadcopter like CF with STM32F103C8T6 controller. Are you also starting from 0 or if you can please tell me where can I find ready made PCB and stuff?
