Yaw Angle Control in Python Cflib
GriffinBonner
Post by GriffinBonner »
I understand how to define a SetHoverSetpoint function and send to the commander with commanderSetSetpoint in firmware to achieve a yaw angle instead of a yaw rate, but I am not sure how to do this using the python library. I am trying to change the yaw angle of the crazyflie based on the output of a neural network running on the host pc, but I do not know the equivalent command in the python library or how to modify the modes of a setpoint:
setpoint->attitude.yaw = yaw;
Is this possible? or do I need to write my own control implementation in python using the yaw rate?
Thanks in advance,
Griffin
jonasdn
Re: Yaw Angle Control in Python Cflib
Post by jonasdn »
The short answer: yes, you need to write your own!
You can look, in the firmware code in crtp_commander_generic.c: https://github.com/bitcraze/crazyflie-f ... eric.c#L39
On how to define a new packet type, and then you need to add the corresponding "send_setpoint" function to the python code!
Good luck!
Jonas
