using SyncLogger with an array of configurations
cafeciaojoe
Post by cafeciaojoe »
Hi.
I am trying to use SyncLogger with an array and don't exactly understand how ther person in this forum post did it viewtopic.php?f=11&t=4450&p=20329&hilit ... ger#p20329. Alot of their code is commented out... do you need to use two for loops for the two configurations? I get two prints of data_1, data_2 but then I get a key error for
'stateEstimate.x'
    def flight_logger(self):
        logger.info('Starting flight logger thread')
        log_angle = LogConfig(name='lighthouse', period_in_ms=100)
        log_angle.add_variable('lighthouse.rawAngle0x', 'float')
        log_angle.add_variable('lighthouse.rawAngle0y', 'float')
        log_angle.add_variable('lighthouse.rawAngle1x', 'float')
        log_angle.add_variable('lighthouse.rawAngle1y', 'float')
        log_position = LogConfig(name='Position', period_in_ms=100)
        log_position.add_variable('stateEstimate.x', 'float')
        log_position.add_variable('stateEstimate.y', 'float')
        log_position.add_variable('stateEstimate.z', 'float')
        rawAngle0x = [0, 0]
        rawAngle0y = [0, 0]
        rawAngle1x = [0, 0]
        rawAngle1y = [0, 0]
        state_estimate = [0, 0, 0]
        with SyncLogger(self._cf, [log_angle,log_position]) as log:
            for log_entry_1 in log:
                for log_entry_2 in log:
                    data_1 = log_entry_1[1]
                    data_2 = log_entry_2[1]
                    print(data_1, data_2)
                    rawAngle0x.append(data_1['lighthouse.rawAngle0x'])
                    rawAngle0x.pop(0)
                    rawAngle0y.append(data_1['lighthouse.rawAngle0y'])
                    rawAngle0y.pop(0)
                    rawAngle1x.append(data_1['lighthouse.rawAngle1x'])
                    rawAngle1x.pop(0)
                    rawAngle1y.append(data_1['lighthouse.rawAngle1y'])
                    rawAngle1y.pop(0)
                    state_estimate[0] = data_2['stateEstimate.x']
                    state_estimate[1] = data_2['stateEstimate.y']
                    state_estimate[2] = data_2['stateEstimate.z']
                    if rawAngle0x[0] == rawAngle0x[1] and rawAngle0y[0] == rawAngle0y[1] and rawAngle1x[0] == rawAngle1x[1] and rawAngle1y[0] == rawAngle1y[1]:
                        self.cf_pos = Position(float('nan'), float('nan'), float('nan'))
                        # print(self.cf_pos)
                    else:
                        self.cf_pos = Position(state_estimate[0], state_estimate[1], state_estimate[2])
PhD Student
RMIT University
School of Design
http://www.cafeciaojoe.com
Re: using SyncLogger with an array of configurations
No, you only need one for loop, but in each iteration you get either log data for log_angle or log_position, but not both. You have to check that the key actually exists in the dictionary before reading
                    if 'stateEstimate.x' in data_1:
                        x = data_1['stateEstimate.x']
                        # Use x...
