Run examples
Posted: Thu Jan 07, 2021 8:17 pm
by BadWoman
I am just starting to setup my AI-deck, but I keep running into issues of not able to run the examples. It says Error 127.
Re: Run examples
Posted: Fri Jan 08, 2021 10:24 am
by kimberly
Hi! You need to be more descriptive about your problem. For example:
- On what OS are you?
- Which version of the gap8 SDK are you using?
- Are you using the docker containers to flash the example
- Are you trying to flash the gap8 chip or the nina?
Re: Run examples
Posted: Sun Jan 17, 2021 3:27 am
by BadWoman
I am not certain of what version of gap8 SDK I am using since my professor gave the ai deck to me in a small bag. I am not sure how to choose the correct board when using source sourceme.sh command.
Re: Run examples
Posted: Tue Jan 19, 2021 6:43 am
by kimberly
It seems that you would need to read up on documentation first You can find the AIdeck documentation
here, and the information on the
gap8 SDK here. Moreover, working with the AIdeck requires an experience in embedded programming experience, so if that is not the case, there is anybody in your lab that is able to help you with this?
You need to source the aideck with:
in the gap8 sdk.
