I am trying to use the command:
python position_commander_demo.py
When I run it, it gives me this error:
File "position_commander_demo.py", line 34, in <module>
import cflib.crtp
ImportError: No module named cflib.crtp
How do I fix this error?
Re: ImportError: No module named cflib.crtp
It seems that cflib has not been installed on your computer.
Could you run the following command in your terminal?
Also make sure that your python version is 3.0 or up. Or else use
pip3 install cflibCode: Select all
python3 position_commander_demo.pyRe: ImportError: No module named cflib.crtp
I have used these commands and it is working now, thank you!
I have also run into another problem when I use the "python3 position_commander_demo.py", it gives me this error: "usb.core.USBError: [Errno 16] Resource busy".
Could you please help me with this problem? Thank you!
Perfect!
that error code means that the USB port of your crazyradio is already been used. This is for instance if you have the cfclient connected to the crazyflie but you want to run a separate pythonscript on that same crazyflie as well using the same crazyradio. This is not possible so you would need to disconnect the crazyflie from the cfclient first.
If this is not the case, usually a quick disconnect and connect of the Crazy radio PA quickly fixes things as well.
