Disconnection in the swarm
wslwsl
Post by wslwsl »
When we operate the multiple crazyflie 2.1 using swam, one or two of them sometimes are disconnected.
I'm afraid that I'll run into disconnection issues in an important demonstration.
Is there any way to solve the problem?
Re: Disconnection in the swarm
hi! How many crazyflies are in your swarm and how many crazyradio PAs do you have? If you are using mulitple PAs, are all of them on a different channel?
wslwsl
Post by wslwsl »
Hi! I'm use the 6 crazyflies and one crazyradio PA.
Thankyou
Do you have any more radios at hands that you can add to your setup so that each radios handle 3 Crazyflies.
Are you using the python lib or crazyswarm/ROS?
We have seen random radios issues but they are very hard to track and very inconsistent. I does seems that Mac computer have more issues that PCs, are you using a Mac?
It could also simply be that you are communicating too much data and that one radio is not enough, in that case adding a second radio will definitely help.
