Controlling the LED ring deck from Python
cgpenguin
Post by cgpenguin »
Hey! I am trying to do some simple LED controls from a python script (together with using the movement commander) where basically the LED ring would receive new RGB values at certain interval (currently only need a simple setup where the whole ring uses the same color at the same time). However, I am struggling to figure this out. I tried running the LED-related scripts from the examples folder, but they don't seem to actually make the LEDs change despite appearing like they should. I was trying to look for a guide for doing this that would explain the basics, but couldn't find one. Some help would be really appreciated.
cgpenguin
Re: Controlling the LED ring deck from Python
Post by cgpenguin »
I wanted to note that when I run, for example, the basicLedparamSync.py, the script actually runs the lines that are supposed to change the LED ring and I get no errors thrown, but the ring lighting doesn't change. Meanwhile if I change the lighting from the CFClient, it works just fine and I can change the LED mode.
I run the same script (basicLedparamSync.py) as well an for me it works with the LED deck.
What is the output on the terminal with the python script? Does the crazyflie have the latest firmware and are you using the latest version of the cflib as well?
cgpenguin
Post by cgpenguin »
Not with the drone right now so can't test for sure, but iirc it was something like this:
Connecting to the drone (and the radio address is listed here too)
Connected to the drone (and the radio address is listed here too)
And that's it. No more output (I think that's expected from the script).
I also added some extra print() parts in the script to make sure it gets to running all of those lines and it really does.
Yes, the version is very much up to date. Not sure about cflib (again, I'll check it once I am back with the system), but I am sure I already had to get the latest one to get lighthouse scripts to work.
Some other things worth pointing out:
  • I am using a lighthouse deck on the drone too
  • Setting LED ring modes works just fine through cfclient
It is quite strange indeed, so I'm not exactly sure yet what is going on. The cfclient uses the cflib itself, so let's dig in what is the actual difference.
The script you mentioned before changes the parameters of the RGB led module. This is also something that you can do within the cfclient: https://www.bitcraze.io/documentation/r ... parameters. This is as close to the parameter structure of the cflib.
Make sure to set ring.effect to 7 and enter the rgb values in ring.solidGreen -Red -Blue
Please let us know if this works.
cgpenguin
Post by cgpenguin »
I tried changing the values through cfclient parameters tab and it appears to be working just fine. Both effect and solidBlue/solidGreen/solidRed parameters succesfully updated the LED ring. However, it doesn't work through the script.
I even put some print statements between each effect change to ensure they're executing. They're being printed succesfully, yet the lights on the drone do not change.
The output:
Connecting to radio://0/80/2M
Connected to radio://0/80/2M
Making it red...
Turning it off...
Making it fade...
As for cflib, the version I have installed is 0.1.12.1.
cgpenguin
Post by cgpenguin »
I did some further troubleshooting and happened to try adding the LED param use to the autonomousSequence script (since flight + LEDs is planned outcome anyway). What happened was the LEDs did actually update colors, but, despite the param.set_value being executed as the first command after syncing with CF, it only updated several seconds into the flight sequence which was only called afterwards. Disabling the flight sequence results in the LEDs not being updated at all.
Should note that sending params from cfclient yields basically instant reaction on the LED ring.
cgpenguin
Post by cgpenguin »
I additionally made the LEDs change color for each point in the sequence. When the drone starts flying, it doesn't change the lights for a while, but then it really quickly runs all the color changes sent to it before and starts working normally afterwards. Not sure about this behavior. Any ideas how to solve this?
Here's the code I'm currently running that yields those results:
https://pastebin.com/4iHfphbj
So you are trying to change the LED's in flight? Have you tried this example yet from this blogpost?
By the way, your code was not available anymore in the link that you posted. You can use gist?
cgpenguin
Post by cgpenguin »
# -*- coding: utf-8 -*-
#     ||          ____  _ __
#  +------+      / __ )(_) /_______________ _____  ___
#  | 0xBC |     / __  / / __/ ___/ ___/ __ `/_  / / _ \
#  +------+    / /_/ / / /_/ /__/ /  / /_/ / / /_/  __/
#   ||  ||    /_____/_/\__/\___/_/   \__,_/ /___/\___/
#  Copyright (C) 2016 Bitcraze AB
#  Crazyflie Nano Quadcopter Client
#  This program is free software; you can redistribute it and/or
#  modify it under the terms of the GNU General Public License
#  as published by the Free Software Foundation; either version 2
#  of the License, or (at your option) any later version.
#  This program is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
#  You should have received a copy of the GNU General Public License
#  along with this program; if not, write to the Free Software
#  Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
#  MA  02110-1301, USA.
Simple example that connects to one crazyflie (check the address at the top
and update it to your crazyflie address) and send a sequence of setpoints,
one every 5 seconds.
This example is intended to work with the Loco Positioning System in TWR TOA
mode. It aims at documenting how to set the Crazyflie in position control mode
and how to send setpoints.
import time
import cflib.crtp
import random
# URI to the Crazyflie to connect to
uri = 'radio://0/80/2M'
# Change the sequence according to your setup
#             x    y    z  YAW
sequence = [
    (0.0, 0.0, 0.25, 0),
    (0.0, 0.0, 0.5, 0),
    (0.1, 0.1, 0.5, 0),
    (0.0, 0.2, 0.5, 0),
    (-0.1, 0.1, 0.5, 0),
    (0.0, 0.0, 0.5, 0),
    (0.1, -0.1, 0.5, 0),
    (0.0, -0.2, 0.5, 0),
    (-0.1, -0.1, 0.5, 0),
    (0.0, 0.0, 0.5, 0),
    (0.0, 0.0, 0.05, 0)
scaling = (2.0, 2.0, 1.0)
offset = (0.0, 0.0, 0.0)
    log_config = LogConfig(name='Kalman Variance', period_in_ms=500)
    log_config.add_variable('kalman.varPX', 'float')
    log_config.add_variable('kalman.varPY', 'float')
    log_config.add_variable('kalman.varPZ', 'float')
    var_y_history = [1000] * 10
    var_x_history = [1000] * 10
    var_z_history = [1000] * 10
    threshold = 0.001
        for log_entry in logger:
            data = log_entry[1]
            var_x_history.pop(0)
            var_y_history.pop(0)
            var_z_history.pop(0)
            min_x = min(var_x_history)
            max_x = max(var_x_history)
            min_y = min(var_y_history)
            max_y = max(var_y_history)
            min_z = min(var_z_history)
            max_z = max(var_z_history)
            # print("{} {} {}".
            #       format(max_x - min_x, max_y - min_y, max_z - min_z))
                    max_z - min_z) < threshold:
                break
def reset_estimator(scf):
    cf = scf.cf
    time.sleep(0.1)
    wait_for_position_estimator(cf)
def position_callback(timestamp, data, logconf):
    x = data['kalman.stateX']
    y = data['kalman.stateY']
    z = data['kalman.stateZ']
    print('pos: ({}, {}, {})'.format(x, y, z))
def start_position_printing(scf):
    log_conf = LogConfig(name='Position', period_in_ms=500)
    log_conf.add_variable('kalman.stateX', 'float')
    log_conf.add_variable('kalman.stateY', 'float')
    log_conf.add_variable('kalman.stateZ', 'float')
    scf.cf.log.add_config(log_conf)
    log_conf.data_received_cb.add_callback(position_callback)
    log_conf.start()
    cf = scf.cf
    for position in sequence:
        print('Setting position {}'.format(position))
        cf.param.set_value('ring.solidRed', str(random.randint(0, 255)))
        cf.param.set_value('ring.solidGreen', str(random.randint(0, 255)))
        cf.param.set_value('ring.solidBlue', str(random.randint(0, 255)))
        for i in range(10):
            cf.commander.send_position_setpoint(position[0] * scaling[0] + offset[0],
                                                position[1] * scaling[1] + offset[1],
                                                position[2] * scaling[2] + offset[2],
                                                position[3])
            time.sleep(0.1)
    cf.commander.send_stop_setpoint()
    time.sleep(0.1)
if __name__ == '__main__':
    with SyncCrazyflie(uri, cf=Crazyflie(rw_cache='./cache')) as scf:
        cf = scf.cf
        # Set solid color effect
        cf.param.set_value('ring.effect', '7')
        # Set the RGB values
        cf.param.set_value('ring.solidRed', '0')
        cf.param.set_value('ring.solidGreen', '200')
        cf.param.set_value('ring.solidBlue', '150')
        # start_position_printing(scf)
This is the code I was testing on. Will look into the code you sent, thanks.
