[Solved] Crazyflie 1.0 Motor Mount Compatibility
bma
Post by bma »
Will the crazyflie 1.0 motor mounts listed here (https://store.bitcraze.io/products/craz ... otor-mount) fit the crazyflie 2.1 board? Also, are these meant for 6mm diameter motors?
Re: Crazyflie 1.0 Motor Mount Compatibility
Unfortunately CF1 motor mounts do not fit on a CF2.1.
They are designed for 6mm motors though.
bma
Post by bma »
I see. Do you have any suggestions for fitting the crazyflie 2.1 with 6mm motors?
I would try to use a CF2 motor mount (7 mm) and put some tape (or similar) around the 6 mm motor to make it a bit bigger.
bma
Post by bma »
I'll give that a shot.
Thanks for the help!
edit: I tried it and the tape + 7mm motor mounts works perfectly!
