flying a crazyflie using uav_trajectories
anomi
Post by anomi »
Hello
After going through all the steps to install tool uav : https://github.com/whoenig/uav_trajectories.
I managed to generate my bezier1 file, now I would like to know how I can fly my crazyflie with a csv file and autonomous_sequence_high_level
Thanks in advance
Re: flying a crazyflie using uav_trajectories
The autonomous_sequence_high_level.py example is probably your best starting point, it uses polynomials though instead of bezier curves. It is possible to upload bezier curves to the high level commander as well but we don't have any example code for that.
I have not used the uav_trajectories tool my self and I'm not sure of the output format, but I think it is likely that it can output the polynomial format as well.
anomi
Post by anomi »
Thank you for your reply
I generate the beziez file, i think is polynomial format, and after that i wrote a script to read each line of my csv file, i paste the result to autonomous_sequence_high_level.py.
but the problem i get this error when a execute the autonomous_sequence_high_level.py.
Connecting to radio://0/80/2M
Connected to radio://0/80/2M
Uploading data
  File "autonomous_sequence_high_level.py", line 222, in <module>
    duration = upload_trajectory(cf, trajectory_id, figure8)
  File "autonomous_sequence_high_level.py", line 194, in upload_trajectory
    Uploader().upload(trajectory_mem)
  File "autonomous_sequence_high_level.py", line 114, in upload
    trajectory_mem.write_data(self._upload_done)
  File "/home/ensea/.local/lib/python3.6/site-packages/cflib/crazyflie/mem.py", line 705, in write_data
    data += struct.pack('<ffffffff', *poly4D.yaw.values)
struct.error: pack expected 8 items for packing (got 0)
My script to display the Bezier file:
inp=open("bezier1.csv","r")
for line in inp:
	print("["+line+", ],")
	print("# noqa")
inp.close()
import time
import cflib.crtp
from cflib.crazyflie.mem import MemoryElement
from cflib.crazyflie.mem import Poly4D
# URI to the Crazyflie to connect to
uri = 'radio://0/80/2M'
# The trajectory to fly
# See https://github.com/whoenig/uav_trajectories for a tool to generate
# trajectories
# Duration,x^0,x^1,x^2,x^3,x^4,x^5,x^6,x^7,y^0,y^1,y^2,y^3,y^4,y^5,y^6,y^7,z^0,z^1,z^2,z^3,z^4,z^5,z^6,z^7,yaw^0,yaw^1,yaw^2,yaw^3,yaw^4,yaw^5,yaw^6,yaw^7
figure8 = [
# noqa
[1.72041,0.0,0.45354900000000203,1.4156000000000037,0.0,0.45354900000000137,1.4156000000000024,0.0,0.4535490000000007,1.4156000000000009,0.0,0.4535490000000002,1.4155999999999997,0.0,0.2186845735500494,1.6468115571735393,0.0,0.14234955019294382,1.7003964313322577,0.0,0.08780304405130135,1.730746419595408,0.0,0.05076597769212654,1.7359074262104741
# noqa
[1.40258,0.0,0.05079959999999973,1.7359500000000054,0.0,0.020623892774285467,1.7401835875457183,0.0,0.0020958772321647,1.7276907495965643,0.0,-0.007098326149691678,1.6974211618160533,0.0,0.04642770923247397,1.5127286697738598,0.0,0.04948934440006808,1.4664989260894128,0.0,0.04241452445115912,1.4316076010282566,0.0,0.024564238709935182,1.4091893896135694
# noqa
[1.81632,0.0,0.02455950000000041,1.4091900000000037,0.0,0.0014388361920003034,1.3801540490057167,0.0,-0.03975636363345168,1.3720316749566839,0.0,-0.10041882501859267,1.3872881878854093,0.0,-0.3523352490943053,1.6542543194201456,0.0,-0.39077187757635445,1.7059186370631982,0.0,-0.4081921725479214,1.7341800661638844,0.0,-0.40637261108588163,1.7390780159761512
# noqa
[1.15497,0.0,-0.40635900000000136,1.7390800000000053,0.0,-0.4051942045052152,1.7421957295698607,0.0,-0.3962455869305774,1.7358649565612423,0.0,-0.37996746264531134,1.7200976705154962,0.0,-0.34064154852082773,1.6613532219634373,0.0,-0.33434655118642864,1.6188821078105882,0.0,-0.33052368696172085,1.5791613842281258,0.0,-0.3299255458842625,1.543258601366379
# noqa
[1.17625,0.0,-0.32992400000000066,1.5432700000000044,0.0,-0.32931309607857184,1.506712990178574,0.0,-0.3320454561229688,1.4741211431922632,0.0,-0.33891465527145126,1.4466255279641804,0.0,-0.45795162035176884,1.466009966289841,0.0,-0.5071180980427636,1.478700424632517,0.0,-0.5549201168094697,1.4918632077745593,0.0,-0.6007691497139778,1.506088752416706
# noqa
[0.824838,0.0,-0.6007490000000021,1.5060800000000047,0.0,-0.6328917585200013,1.5160547659340031,0.0,-0.6640703723867443,1.5265517841780623,0.0,-0.6940807001685951,1.537774586877349,0.0,-0.7195290866835702,1.5670777140548238,0.0,-0.7217980588922879,1.5783559673831655,0.0,-0.7209099103997235,1.5891923557998044,0.0,-0.7167672806294639,1.5996918685171442
# noqa
[1.03404,0.0,-0.7167670000000024,1.599700000000005,0.0,-0.7115733568360016,1.612862708776003,0.0,-0.7012647302085143,1.6254950853293135,0.0,-0.6856489729688651,1.6378019944611641,0.0,-0.610846890915947,1.6444070457736917,0.0,-0.5706149873208214,1.633814022410025,0.0,-0.5320136714026726,1.6205831586825339,0.0,-0.4944374993413341,1.604807263091334
# noqa
[1.07832,0.0,-0.4944340000000013,1.6048000000000051,0.0,-0.4552464647885722,1.588349150080003,0.0,-0.4171723742958976,1.5691310585602447,0.0,-0.3795243720723396,1.5472513330107367,0.0,-0.3323242069050696,1.4808651501395513,0.0,-0.3326950800864702,1.4572333530234098,0.0,-0.3380019602211653,1.435941546400985,0.0,-0.3482742267620078,1.4173385138778989
# noqa
[1.50767,0.0,-0.348285000000001,1.4173500000000039,0.0,-0.36265891039857207,1.3913506616128597,0.0,-0.3867514889371643,1.3706177206264327,0.0,-0.42065478721871163,1.3561137418432585,0.0,-0.5765503250446375,1.450722856275519,0.0,-0.6605810447249665,1.4692553559018622,0.0,-0.737790520340273,1.4868213220290727,0.0,-0.8103096605492475,1.5048018102810232
# noqa
[1.0071,0.0,-0.8103150000000029,1.5047800000000044,0.0,-0.8587596751714306,1.5167778556557174,0.0,-0.9051126327437319,1.5289539774124208,0.0,-0.9500094257317719,1.5417167095121977,0.0,-0.9945335900614083,1.5943253092111231,0.0,-0.9945992525500624,1.5992895439465735,0.0,-0.9899033319383517,1.6027387704008105,0.0,-0.9799862427537356,1.6046759722867474
# noqa
[1.14376,0.0,-0.9799830000000032,1.604670000000005,0.0,-0.9687166535508593,1.606865185889146,0.0,-0.9507125837215306,1.6071053050884287,0.0,-0.9252940272313683,1.6053899841868189,0.0,-0.8085728563040759,1.5231975705882281,0.0,-0.7952987129488094,1.492712777156091,0.0,-0.7898660710930852,1.4643457477903659,0.0,-0.7926668355927884,1.438658614644197
# noqa
[0.544044,0.0,-0.7926740000000024,1.4386500000000042,0.0,-0.7940076228292587,1.4264274297754314,0.0,-0.7972042245389489,1.4148100267700607,0.0,-0.8023059430017195,1.4038580270516772,0.0,-0.8245069528538593,1.398260766667467,0.0,-0.832662752269065,1.395405579984961,0.0,-0.8417816295981322,1.3939852244673818,0.0,-0.8518136897216835,1.3940122183030939
# noqa
[1.69781,0.0,-0.851812000000002,1.394010000000004,0.0,-0.883117190957144,1.3940937825577053,0.0,-0.9233140737679112,1.4082728658342223,0.0,-0.9708907125612308,1.43692829676543,0.0,-1.2987719936016069,1.5968187727359617,0.0,-1.3054573615188378,1.607415239657779,0.0,-1.2992953968142738,1.6122634363930195,0.0,-1.2827923542635773,1.6100167671973775
# noqa
[1.28011,0.0,-1.2827400000000042,1.6100100000000053,0.0,-1.2702722772185744,1.6083135963992747,0.0,-1.25191592085108,1.602581978344977,0.0,-1.228742102700686,1.592236249173642,0.0,-1.0614295529709485,1.4683795586406023,0.0,-1.0634850331374552,1.4575294016982703,0.0,-1.0687615371287555,1.448776337883575,0.0,-1.0780257228010761,1.4410645970763927
# noqa
[0.51015,0.0,-1.0780100000000032,1.4410500000000042,0.0,-1.0816977796078593,1.4379719516721456,0.0,-1.0860174473578446,1.4350577289040503,0.0,-1.0910170709847735,1.432240052419812,0.0,-1.1256314867823667,1.4082953762478219,0.0,-1.128693753815635,1.403544564188703,0.0,-1.1310194485284573,1.3983229395489005,0.0,-1.1325534395154824,1.3926285611744078
# noqa
[1.56718,0.0,-1.1325500000000028,1.3926300000000038,0.0,-1.1372391592780018,1.3751405846360027,0.0,-1.1343976034665855,1.3531971987485623,0.0,-1.1222808427185083,1.3267596214585937,0.0,-1.3488618352415238,1.4560629361511097,0.0,-1.4457878115858729,1.5245169839717276,0.0,-1.527878843582636,1.5845178832966123,0.0,-1.5588744179170142,1.6073529388653878
# noqa
[0.201968,0.0,-1.558850000000005,1.607340000000005,0.0,-1.562842561129146,1.6102812888365745,0.0,-1.5659863688048523,1.612605169819149,0.0,-1.5682038072577593,1.6142501748569646,0.0,-1.5699599859086637,1.615508397590891,0.0,-1.569960013439184,1.6155083932971006,0.0,-1.5699600332545045,1.6155083750936954,0.0,-1.5699600239692961,1.6155083387477018
# noqa
class Uploader:
    def __init__(self):
        self._is_done = False
    def upload(self, trajectory_mem):
        print('Uploading data')
        while not self._is_done:
            time.sleep(0.2)
    def _upload_done(self, mem, addr):
        print('Data uploaded')
        self._is_done = True
    log_config = LogConfig(name='Kalman Variance', period_in_ms=500)
    log_config.add_variable('kalman.varPX', 'float')
    log_config.add_variable('kalman.varPY', 'float')
    log_config.add_variable('kalman.varPZ', 'float')
    var_y_history = [1000] * 10
    var_x_history = [1000] * 10
    var_z_history = [1000] * 10
    threshold = 0.001
        for log_entry in logger:
            data = log_entry[1]
            var_x_history.pop(0)
            var_y_history.pop(0)
            var_z_history.pop(0)
            min_x = min(var_x_history)
            max_x = max(var_x_history)
            min_y = min(var_y_history)
            max_y = max(var_y_history)
            min_z = min(var_z_history)
            max_z = max(var_z_history)
            # print("{} {} {}".
            #       format(max_x - min_x, max_y - min_y, max_z - min_z))
                    max_z - min_z) < threshold:
                break
def reset_estimator(cf):
    time.sleep(0.1)
    wait_for_position_estimator(cf)
def activate_high_level_commander(cf):
    cf.param.set_value('commander.enHighLevel', '1')
def activate_mellinger_controller(cf):
    cf.param.set_value('stabilizer.controller', '2')
def upload_trajectory(cf, trajectory_id, trajectory):
    trajectory_mem = cf.mem.get_mems(MemoryElement.TYPE_TRAJ)[0]
    total_duration = 0
    for row in trajectory:
        duration = row[0]
        x = Poly4D.Poly(row[1:9])
        y = Poly4D.Poly(row[9:17])
        z = Poly4D.Poly(row[17:25])
        yaw = Poly4D.Poly(row[25:33])
        trajectory_mem.poly4Ds.append(Poly4D(duration, x, y, z, yaw))
        total_duration += duration
    cf.high_level_commander.define_trajectory(trajectory_id, 0,
                                              len(trajectory_mem.poly4Ds))
    return total_duration
def run_sequence(cf, trajectory_id, duration):
    commander = cf.high_level_commander
    commander.takeoff(1.0, 2.0)
    time.sleep(3.0)
    relative = True
    commander.start_trajectory(trajectory_id, 1.0, relative)
    time.sleep(duration)
    commander.land(0.0, 2.0)
    time.sleep(2)
    commander.stop()
if __name__ == '__main__':
    with SyncCrazyflie(uri, cf=Crazyflie(rw_cache='./cache')) as scf:
        cf = scf.cf
        trajectory_id = 1
        # activate_mellinger_controller(cf)
        print('The sequence is {:.1f} seconds long'.format(duration))
        reset_estimator(cf)
Check the order of the columns in your csv file. I have a faint recollection of that the duration is the last column in the csv but the fist column in the python file.
anomi
Post by anomi »
I just checked my Csv file I found that the duration is in the first column like the python file.
The problem is that the Csv file contains 25 columns but on the other hand the python file needs 33 columns to fly, that's why he displayed this error:
The uav_trajectories tool generates points in my bezier file without the last 8 yaw values.
I think that's the problem
Yes, that would be a problem. You can just set all the yaw data to 0
anomi
Post by anomi »
yes i did that before, I have the drone that flies but is not stable, and does not follow my trajector.
Hi Sorry for the late reply, but it seems that this is also something that we don't know exactly the answer to either. Have you found a solution in the mean time?
