sketchup model
er1c
sketchup model
Post by er1c »
had my crazyflie quadcopter for a few weeks now, pretty impressed by how stable it flies given it's size!
I wanted to look at designing my own crazyflie frame for 3dprinting after reading about Vger's experiments in another thread:
http://forum.bitcraze.se/viewtopic.php? ... ilit=frame
couldn't find any 3dmodel that I can use for reference, so I made my own, from the schematics on the wiki page and a bit of measuring.
thought I'd share.
distances (motor to motor / propeller diameter etc) should be mostly accurate, maybe +-0.5mm
eric
cf_model_s.zip
superseded - see cf_mocel_s_revA files below
(229.67 KiB) Downloaded 508 times
marcus
Re: sketchup model
Post by marcus »
Hi Eric,
That's a really nice model. Great work!
If you haven't seen it already we have a repository for mechanical parts where we store various models and drawings. Would you mind if we added your model so that people could find it more easily? Any chance you have a Pro version of SketchUp and can export the model in DXF as well?
/Marcus
er1c
Re: sketchup model
Post by er1c »
thanks!
please do add it to the repository! I hadn't realise there's a mechanical section in the repository :)
I can export a dxf, but it'll have to be sometime next week, currently out and about...
(or someone else with sketchup pro might be able to help)
E
foosel
Re: sketchup model
Post by foosel »
Whoaaa O_O That's indeed a nice model! We really need a karma plugin for this board ;)
DesTinY
Re: sketchup model
Post by DesTinY »
Really great 3D model eric!
BTW: For the meantime here is the exported AutoCAD .dxf file: DOWNLOAD
marcus
Re: sketchup model
Post by marcus »
Great! Both the files are added to the mechanics repo.
er1c
Re: sketchup model
Post by er1c »
while working on my crazyflie frame today, I noticed the centre point I used for rotation in my previous model was slightly off.
fixed it, so here is the revised version of the model, in sketchup and dxf format.
Eric
cf_model_s_revA dxf.zip
dxf format
(244.26 KiB) Downloaded 427 times
cf_model_s_revA skp.zip
revisionA, sketchup 7
(210.18 KiB) Downloaded 416 times
marcus
Re: sketchup model
Post by marcus »
Great! The models that are in the mechanical repo have been updated as well.
markusw1984
Re: sketchup model
Post by markusw1984 »
Hi Crazyflie Team,
i´m interested in creating my own crazyflie body. is it possible to offer a STEP file, where a quadcopter is included?
Best wishes,
Markus
Re: sketchup model
I'm not completely sure what you are meaning with "where a quadcopter is included"?
