Running multiranger_pointcloud.py example
Re: Running multiranger_pointcloud.py example
Post by kristoffer »
It is probably related to qt5 or vispy? Vispy is using QT but I'm not sure what the problem is.
Have you tried to upgrade or reinstall vispy and qt5.
You can do it from pip, and since it seems as your ide is using python 3, you should probably use pip3.
on the lines of
pip3 install vispy
pip3 install PyQt5
boped
Post by boped »
Yes I think Qt5 is the Problem. Thanks for replying.
But if i try to install it, this error appears:
pi@raspberry:~ $ pip3 install PyQt5
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting PyQt5
Using cached https://files.pythonhosted.org/packages ... 4.2.tar.gz
Installing build dependencies ... done
Complete output from command python setup.py egg_info:
File "<string>", line 1, in <module>
File "/usr/lib/python3.7/tokenize.py", line 447, in open
buffer = _builtin_open(filename, 'rb')
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/pip-install-8hyb0_sw/PyQt5/setup.py'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-8hyb0_sw/PyQt5/
I'm afraid I can't offer much help, but maybe this is useful https://stackoverflow.com/questions/597 ... ect=1&lq=1
