Running multiranger_pointcloud.py example
emoyers
Post by emoyers » Wed Mar 11, 2020 3:15 am
I'm having problems to run multiranger_pointcloud.py example, Do I need to use an specific version of python or vispy?
I'm getting this error: AttributeError: 'CanvasBackend' object has no attribute 'setParent'
If I comment these 2 lines, I'm able to run the script but I cannot visualize the datapoints:
#self.canvas.native.setParent(self)
#self.setCentralWidget(self.canvas.native)
Do you any idea on what can be the problem and how can I fix it?
Re: Running multiranger_pointcloud.py example
Post by tobias » Wed Mar 11, 2020 12:01 pm
Yes this sound like a version issue. Are you running the example with python2 or python3? I'm not sure it works with python2.
emoyers
Post by emoyers » Thu Mar 12, 2020 1:07 am
I'm using python 3.5.2. Do I need an specific version for vispy?
Post by tobias » Thu Mar 12, 2020 8:47 am
I'm running python 3.7.5 and it works for me but after smaller investigation it seams to be a Qt issue. They broke the API at some point but looks fixed now. Easiest solution is probably to update everything rather then downgrading Qt.
emoyers
Post by emoyers » Thu Mar 12, 2020 11:05 pm
I'm using ubuntu right now. When you say update everything, do you mean run "app-get update" and install python 3.7.5?
Post by tobias » Fri Mar 13, 2020 8:04 am
You could try "app-get update" but it depends on what Ubuntu version (e.g. 19.04) you are on. Possible, at the version you have, 3.5.2 might be the latest.
emoyers
Post by emoyers » Sat Mar 14, 2020 3:28 am
Thanks @tobias I was able to run it with python 3.7.5.
