[SOLVED] Crazyfliedied
Posted: Sun Dec 29, 2019 4:55 pm
by RyanMco
Hi guys!
Im really in a shock ..my crazyflie was working fine yesterday with battery attached to it, I tried today to turn it on by a battery it didn't work, but tried by cabel USB it works fine (the leds are on and it shows me that's working fine - blue led and red led blinking ..all fine)
my problem now is why it doesn't work with the battery attached to it? ofcourse the battery is fully .. what could be the problem? when I attach the battery no led is on at all! .. how could I solve that problem?! thanks alot
Re: Crazyfliedied
Posted: Tue Dec 31, 2019 10:26 am
by kimberly
On the first thought, it seems that the battery connector on the board has been broken. Are you using the Crazyflie 2.1 or 2.0? Can you send us a photo of the battery connector on the board of your crazyflie?
Re: Crazyfliedied
Posted: Tue Dec 31, 2019 5:04 pm
by RyanMco
2.1
the battrey isn't broken, because the same battrey I attach it to another drone 2.1 and it works fine ..
Re: Crazyfliedied
Posted: Mon Jan 06, 2020 1:52 pm
by kimberly
I am not talking about the battery, but the battery connector on the Crazyflie (the black and red wire that are on the board itself). The metal wire inside those wires might be disconnected, so you would need to test the continuity of these with a multimeter (or if they are shorted somewhere).
Re: Crazyfliedied
Posted: Thu Jan 16, 2020 7:12 pm
by RyanMco
fixed!
there was an internal short in the wires of battrey!
thanks
