Do I need a crazyFlie if I have the bolt?
r0b0tn1k
Post by r0b0tn1k » Fri Dec 06, 2019 9:28 pm
I am looking at buying the bolt.
If I do get it, do I need to get the crazyFlie or is the bolt just the crazyFlie in a bigger package?
And also, if I order know, will there be any shipping delays?
Re: Do I need a crazyFlie if I have the bolt?
Post by arnaud » Mon Dec 09, 2019 10:49 am
The bold is essentially a Crazyflie without the brushed motors and with brushless controller connector instead, so no you do not need a Crazyflie with the bolt, it is a Crazyflie.
We are shipping multiple times per week so if you order now from store.bitcraze.io your order will be shipped within a couple of day.
r0b0tn1k
Post by r0b0tn1k » Tue Dec 10, 2019 2:58 pm
Addon question:
I already have the big deck quad.
Why should I get the bolt? What's the advantage?
Post by arnaud » Tue Dec 10, 2019 3:41 pm
The Crazyflie bolt implements brushless motor driver output independently of the expansion deck port, this means that the deck port is completly free to attach any deck while the bigquad deck uses quite a lot IO on the deck port. Bolt is also a single-board solution versus the CF2+bigquad two board stack.
But, If CF2 + bigquad deck does fullfill you needs there is no need to replace it by a CF bolt.
r0b0tn1k
Post by r0b0tn1k » Wed Dec 11, 2019 10:56 am
My crazyflie looks bulky as it is, let alone if I add the big deck quad.
I think I'll buy the bolt, but after the holidays, so it dont get stuck in the mail with everyone else's Christmas shopping! :)
