Re: Log TOC variables/gyro and acc values
Posted: Mon Jul 15, 2019 4:13 pm
Unfortunately, I am still having trouble with the gyroscope. I realized that when I tilt the crazyflie while connected to the CF Client, the flight data screen does not show the tilt. The console says that the self tests all pass though.
I tried installing the latest client and lib as you suggested but unfortunately that did not solve the problem. I also ordered and tested a new crazyflie to see if the gyroscope sensor itself was messed up, but it doesn't seem like that is the case.
For additional and probably unecessary info, before I changed to the newest client, had another crazyflie with firmware from 2018 that did successfully show tilt in the client while the flashed CF did not.
Do you have any ideas about what could be going wrong?
