Sensor Calibration - M1 is keep blinking
aybarskizilay
Post by aybarskizilay » Thu Mar 14, 2019 10:52 am
Hello everyone,
When I power on CF 2.0, it starts properly and LED M2 and M3 is blue.
However, M1 is keep blinking red LED.
The Console message on CF Client is:
SYS: Build 0:47ee696b2d3c (2018.10) MODIFIED
SYS: I am 0x2035355237485008003E003D and I have 1024KB of flash!
CFGBLK: v1, verification [OK]
DECK_DRIVERS: Found 16 drivers
DECK_CORE: 1 deck enumerated
MPU9250 I2C connection [OK].
AK8963 I2C connection [OK].
LPS25H I2C connection [OK].
ESTIMATOR: Using estimator 2
CONTROLLER: Using controller 1
EEPROM: I2C connection [OK].
AK8963: Self test [OK].
DECK_CORE: Deck 0 test [OK].
SYS: Free heap: 11136 bytes
On the website, it says if M1 is blinking red, that means sensors are not calibrated and it recommends to put on the surface.
Even though I have put the CF on the ground, M1 keeps blinking RED.
Is there a way to calibrate sensors?
Aybars
Re: Sensor Calibration - M1 is keep blinking
Post by arnaud » Wed Mar 20, 2019 10:25 am
If M1 blinks red continiously this is good, this is the heartbeat LED. The rate of blinking increase when the sensors are calibrated. If there is a selftest problem, M1 will blink in burst then the self test has failed. You can see short video showing the two cases in the getting started documentation:
https://www.bitcraze.io/getting-started ... -2-0/#test
From the log, your Crazyflie looks good :).
aybarskizilay
Post by aybarskizilay » Wed Mar 20, 2019 10:57 am
Hi Arnaud,
Thanks for the reply.
