Hover without the Flow deck
thasu
Post by thasu » Mon Sep 03, 2018 6:28 am
Is it possible to hover without the flow deck. I'm using python client to control the CF. If it's possible what is the python command that I need to use?
Re: Hover without the Flow deck
Post by arnaud » Mon Sep 03, 2018 8:14 am
It depends what you need by hover. It is possible to control the Crazyflie with the python lib even without a flow deck the same way the client is doing it: you can send roll-pitch-yaw-thrust (RPYT) setpoint to the Crazyflie and even send altitude-hold setpoint. However, the Crazyflie will not be able to hold a position without the flow deck, it will fairly quickly drift away unless you have a way to detect its position with a camera system or other localisation system.
If you want an example of how to send RPYT setpoints to the Crazyflie you can look at the ramp.py example.
