I want to start the Python-file "autonomousSequence" from the crazyflie-lib-python Folder. After running the python script, the System Shows me the following message
FIle: "autonomousSequence.py", line 37, in <module> Import cflib.crtp
Import Error: No module named cflib.crtp
Do i have to copy the file in the cflib.crtp Folder ?
Thanks for the help & kindly regards
Lama
Crazyflie Python Problem
Re: Crazyflie Python Problem
you need the lib installed in your system. You can install the stable version with "pip3 install cflib". If you plan to develop on the lib as well, you can install it from source by typing "pip3 install -e ." in the crazyflie-lib-python folder.
Depending on you system you have to use pip or pip3. On Linux and mac it is better to use pip3 and then run the script with python3. On windows, if you only have python3 installed you can use pip and python. If you need to use Python2, the lib is compatible with it too.
Hello arnaud and thanks for your answer.
The lib was already installed. We upgraded the libary and used phyton3 to run the script instead of python.
Then I assume it is now working. Great!
Yes this worked perfectly fine!
Thanks for your help.
