Larger Propellers
jseanm1
Larger Propellers
Post by jseanm1 »
I'm looking to attach 3" props to the CF motors. I haven't found props that support the 0.8mm shaft yet. Has anyone attached larger props to the same motors? Where did you buy them from?
Janindu
Re: Larger Propellers
The current propellers are pretty well matched to the motors and putting bigger propellers might overheat the motors. I suggest you to switch out the motors as well in that case, e.g. 7x20mm motors with 1mm shaft that will fit in the motor mounts.
