setting hover function
jERRY
Post by jERRY » Thu Aug 03, 2017 3:04 am
Hi All
the Crazyflie Nano 2 support the "setting hover" function ??
if not, Is there any possible to add the sensor to control ??
jERRY
Re: setting hover function
Post by arnaud » Thu Aug 03, 2017 7:08 am
Hi jERRY,
Crazyflie 2.0 has a pressure sensor (altimeter) onboard that allows to fly in altitude-hold mode.
For more precise height-hold behavior, you can add a zRanger deck or a Flow deck to the Crazyflie. With the flow deck the Crazyflie 2.0 is capable of keeping a stable position over the ground (hover mode).
