Will it affect the Crazyflie's flight if we use the extended pin for the breakout board?
thanhvu94
Post by thanhvu94 » Mon Jun 19, 2017 1:01 pm
I have generated the PWM signal using pin IO1 and Timer10 on the expansion board. And on the breakout expansion board, I solder an IR LED and some resistors. I'm wondering if these will affect the performance of the Crazyflie when I control the Crazyflie using VICON with ROS?
Thank you.
Re: Will it affect the Crazyflie's flight if we use the extended pin for the breakout board?
Post by arnaud » Tue Jun 20, 2017 8:35 am
Any added weight will affect the Crazyflie flight performance, however your addition does not sounds much heavier that the stock battery holder so I would not expect the effect to be big enough to be visible at all.
