Android control and radio dongle rotor power problem
qwertyuiop
Post by qwertyuiop » Thu Jul 21, 2016 10:33 am
Hello
I am novice at using of Crazyflie.
I built Craztflie, updated firmware.
A am able to control it from Android (bluetooth) and all is OK.
A connect to it from VM (radio dongle) and all is OK.
But when I try use android app and crazy flie client from VM in one time I have got the next problem:
Power on motors is very small and CrazyFlie is not fly. Sometimes the power is good and crazy flie flyes up, but very very seldom.
What I do incorrectly?
Re: Android control and radio dongle rotor power problem
Post by arnaud » Fri Jul 22, 2016 9:14 am
Are you sure your phone is not connected via bluetooth at the same time as the VM? If this would happen the result would be similar to what you are describing: both clients would trie to send different setpoints and because one of te client is sending thrust at 0 it would limit the thrust.
/Arnaud
