Python API to set LED status Available???
Cyientist
Post by Cyientist »
Is there a direct python API to set the LED ring expansion settings in our own python program ? Or is there a way to set like self._cf.SetLedStatus() or something similar
Re: Python API to set LED status Available???
Yes, you can use the parameters for setting the "headlight" and the LED-ring effect. You can also set custom patterns using the LED-ring memory.
Have a look at this example for setting parameters and this for setting the LED-ring memory via ZMQ.
The parameters you are interested in are ring.headlighEnable and ring.effect
