Crazyflie 2.0 qi charger
almaz_1c
Post by almaz_1c »
Hello!
I get crazyflie 2.0 with qi wireless charger expansion board connected to quadrotor. Quadrotor turned ON.
I get this http://www.seeedstudio.com/depot/Qi-Wir ... -1997.html turned ON.
Should be charging now?
this should be obvious, but I do not understand
Re: Crazyflie 2.0 qi charger
Post by chad »
When I charge with the Qi charger deck, I turn the Crazyflie on, like you said. Then, set it on a Qi charger base. You know it's charging when the blue LED on M3 arm pulses. There's a small green LED on the Qi board that also lights when there is a good "connection" to the charger. Once the Crazyflie is fully charged, the blue LED on the M3 arm will glow steadily.
almaz_1c
Post by almaz_1c »
Understood. I crepe expansion card over quadrotor.)
