I am curious what the current plans/realizations are regarding using the accelerometer for some basic centering, while hovering or climbing, and the flie isn't receiving pitch-roll commands? In other words using the accelerometer data to help it hold its relative position. Is the 3-axis accelerometer capable of detecting well enough if it's drifting to the left, gets bumped, breeze, etc to allow using that data to try and re-center the flie again to its starting position? Any user given directions with the controller could then also be allowed for, and not compensated against after.
I don't see this mentioned on the wiki wishlist, is it not a possibility given the sensors capabilities or would this be a good place to contribute? The closest things I saw on the wishlist are using openCV to externally manage this on a bigger scale and altitude and heading control. While I can see how the currently unsupported altimeter and magnetometer would offer more precision options for auto stabilizing and programmed flight, once they are working, could the accelerometer not pull off a basic version of the functionality now? This would only be for correcting small drifts in direction.
Thanks! Let me know if this is way off, already being made, etc
