Advanced method to connect the motors to the board
cracklecrackle
Post by cracklecrackle » Tue May 07, 2013 7:45 am
i got my crazyflie last week but i'm in a dispute with myself about the soldering of the motors directly to the board. Soldering itself is not the problem but i rather don't want to solder the motors directly to the board because i think solder an maybe unsolder for later modifications are unnecessary stress for the other components on the board, maybe it would be better to use a connector like this for example: http://www.tme.eu/de/details/nx1001-02s ... 1wr-s-2p/#
But it is hard to get them in 1 mm grid dimension in germany. Do someone of you having experiences or tried a similar connector? Next idea were to use a expansion breadboard but i can't find one with 1 mm grid dimension, do anyone of you know a shop in germany or europe?
Greetings
Patrick
Last edited by cracklecrackle on Tue May 07, 2013 9:02 am, edited 1 time in total.
Crazyflie Nano 10-DOF
atomicdog
Re: Advanced method to connect the motors to the board
Post by atomicdog » Tue May 07, 2013 8:52 am
I don't think you will need to solder and unsolder the wires so many times that you should be worried about damage to other components.
I think adding a connector will add unnecessary weight.
ross123540
Post by ross123540 » Tue May 07, 2013 2:18 pm
Ive already had to swap out two motors due to issues with them...
cracklecrackle
Post by cracklecrackle » Tue May 07, 2013 2:44 pm
ross123540 wrote:Ive already had to swap out two motors due to issues with them...
I think i solder the motors for first tests directly on the board till i find a better solution for this. If i find a vendor i'll post it here or i try to build a solution by my own, i will think about this and try some ideas this weekend.
