very nice work super funny baby you built!
Just having a little big issue:
When controlling the flie via PS3 Controller (sixad ubuntu and cfclient newest hg, as well as recent firmware flashed on the flie) i have the prob that sometimes (i think when PS3 controller gets too far out of range from the laptop) the flie just increases thrust to max and escapes, luckyly i found it the lasttwo times even the last time it was around 100 meters away and in a neighbours garden
The other difference i see from an xbox controller which i had first is, that with the xbox controller thrust never gets below 30 or smth, and i need to use the killswitch if the flie drops.
With the PS3 controller after connecting everything i need at least to move the throttle a bit to get the rotors on.
Is there a known prob for escaping flies?
And if you plan another revision, please add a beeper that tells where the fly is (i think that will be my first mod now, that the beeper starts making a sound if the fly was connected and looses connection to the cfclient app
Thanks a lot for this great "toy"
Cheers Phil
