CF Ignores some of the high-level commands
tugayalperen
Post by tugayalperen »
Hi all,
I was doing repetative tests to make sure our Crazyflie 2.1's stability is okay. The test I was doing is simply using a script so much like test_high_level.py, with 2 CF takeoff-go 2m forward relatively-land and backwards and forwards again... The thing I faced is this, after 15-20 trials, one of the CFs ignores a command such that it does not takeoff, does not land or does not go forward. If I try again, everything works fine. Also I have no warning about link quality issue and I use 2 Crazyradio PA for 2 CFs. I am using crazyflie_ros btw.
I have tried with latest firmwares for stm32, nrf51, crazyradio PA in addition to release verisons of them. When they are flying, stability is perfectly okay. Only problem is that ignoring behaviour.
Re: CF Ignores some of the high-level commands
That is a bit strange. Could it be something with the battery level? Is it always between 15-20 trials or is it more random? What positioning system are you using? Thinking it could be some time related overflow or something like that.
tugayalperen
Hi Tobias,
I am quite sure it is not battery level, I always measure it before and after flight and also the CF which ignores the command can perfectly listen the next one without any problem.
It is not always after many trials, sometimes it ignores the takeoff or the very first go_to command, but it is not very frequent. I would say it is random.
We are using Optitrack and vrpn-client as instructed, nothing fancy. I also monitor the external_position topic and Motive side, they seem okay to me.
If it is an overflow issue, what can I improve? Can it be related to external_position topic's frequency (it is not binded to Motive side frequency, which is 240 Hz). I also tried it with 120 Hz but I encountered with same problem. Should it be lower?
Thanks for helps,
A tricky problem, it sounds like a communication problem, like packet loss or similar but that "shouldn't" happen. If you have any way to replicate it that would help a lot.
whoenig
Post by whoenig »
See also https://github.com/whoenig/crazyflie_ros/issues/140. @tobias: In crazyflie_ros, we resend the command until an acknowledgement is received, but not until we get the answer generated here: https://github.com/bitcraze/crazyflie-f ... #L292-L295. In the firmware, what could cause an acknowledge to be send (NRF), but the packet not being processed on the STM?
tugayalperen
To produce that loss, most critical points are sending many go_to commands one after another (you can think like dividing a trajectory into small linear parts and sending go_to commands accordingly) and using more than one radio for multiple crazyflies i.e. one crazyradio PA for one crazyflie. The situation exists on both cf 2.0 and 2.1. I understand that repeating high-level go_to commands is meaningless since every one them repeats itself until it gets an acknowledge response, yet repeating them solves the problem. By the way, do not think that ignoring behaviour is limited to go_to, it can occur at takeoff or land also.
I have not used the ros driver that much but I know there is a broadcast functionality. I'm guessing you are not using this?
There is no acknowledgement that a packet has been processed by the STM, only that it has been received by the NRF, so potentially something could get lost there, but I doubt it. I will try to make a test for this.
tugayalperen
No, apparently I am not using broadcast messages, instead I am using high-level functions. I am curious about your tests then, thanks.
marcus
Post by marcus »
I've started looking into the missing packages a bit. After looking at the USB communication a few weeks ago we have some scripts that uses the LINK ECHO port (code here). The port will echo back what ever data is sent to it.
When running the test above yesterday I had lots of issues and was loosing packages and geting duplicates. Turns out there was another Crazyflie in our office on the same channel that was causing issues. When only having one Crazyflie on the same channel the test works perfectly :roll:
I'll do a bit more testing this today and see if I can find something.
I solved a bug last week that could lose packet if the packets where not read fast enough by CRTP ports: https://github.com/bitcraze/crazyflie-f ... issues/434. There is not a queue of 16 packets for each ports (only 1 previously) and the Crazyflie will crash if one of these queue overflows.
With this fix and using the fixed USB I cannot get the echo script that Marcus sent to fail anymore, so it seems that we do not have loss packet anymore in the STM32.
