Crazyflie can't calibrate
giandoman
Post by giandoman » Fri Oct 06, 2017 2:06 pm
Hello...again
i have one crazyflie drone that has a strange issue: it starts regularly but the red led that should blink each second after the calibration, actually blinks each 2 seconds. As it can't initialize properly.
Within the client i can connect with the crazyradio PA but i can't see any output on the flight data. So the sensors seem not work properly.
I flashed it with the updated firmware...but nothing.
Do you think it is an hardware problem?
Gianni
Re: Crazyflie can't calibrate
Post by arnaud » Mon Oct 09, 2017 11:27 am
It could be. What is the text displayed in the console when connecting the the Crazyflie. You can see the console by opening the tab with view/tabs/Console.
giandoman
Post by giandoman » Tue Oct 10, 2017 7:25 am
Thanks Arnaud! I'll check later and I'll post the message of the console.
Bye
Gianni
