So everything is running ok with my pa 2
Laced-code
Post by Laced-code »
But I need help opening it in python and maybe help me run it step by step.
Re: So everything is running ok with my pa 2
Can you please give a bit more details.
- What are you trying to achieve (in high-level terms, what is the end goal)?
- What have you tried so far?
- What is the problem, ie. what where you expecting to happen and what happened instead?
This way we will most likely be able to help you :-).
