Crazyradio PA firmware upgrade error
netkimjh
Post by netkimjh » Tue Oct 10, 2017 10:22 pm
solved
Re: Crazyradio PA firmware upgrade error
Post by arnaud » Mon Oct 16, 2017 12:51 pm
The output looks correct and is seems that you are running the latest firmware available (0.53).
Do you have problems with the radio so that you feel you need to upgrade it?
netkimjh
Post by netkimjh » Wed Oct 18, 2017 6:42 pm
solved
Post by arnaud » Thu Oct 19, 2017 7:41 am
The error is most likely caused by a right problem, launching the command with sudo should remove the message.
Did you flash the crazyradio PA firmware?
