i've crazyradio and crazyflie v1. i was able to connect to crazyflie with the crazyradio usb dongle for few days, i was playing with the values of
commander.send_command(...) # parameters to fly
i couldn't segregate the issue. so i thought i'll flash crazyradio and test, then go with crazyflie.
while trying to flash the crazyradio, It throwed error saying it couldn't find the crazyradio usb dongle.
i've also tried
from cflib.cflib.drivers.crazyradio import Crazyradio
cr = Crazyradio()
File "cflib/drivers/crazyradio.py", line 113, in __init__
raise Exception("Cannot find a Crazyradio Dongle")
Exception: Cannot find a Crazyradio Dongle
import usb.core
dev = usb.core.find()
this doesn't gives any new device id than the default one (05ac:0262 on Bus 029 Address 004) when i connect with crazyradio.
but gives some id and changes port for some other devices.
* I am not sure whether the hardware become faulty.
* When i connect the light green and red blinks togeter few times!! so its getting power from the connection.
1. Is it possible to flash it with other means? (I need to check connection first!)
2. Any other way to test whether device working properly?
3. Any other mechanism so that i can connect to crazyflie directly? (eg. i think it have BLE nordic semiconductor)
Thanks for any help.
